1991 Plymouth Breeze
1991 PLYMOUTH BREEZE
CLARENCEH
Engine Cooling problem
i have alot of oil in my antifreeze but no anti frezze in oil
Apr 26, 2008 at 10:51 AM
BMRFIXIT
  • 19,053 POSTS
check radiator and check tranny fluid
most likely the tranny cooler inside the radiator failed and radiator need to be replaced
Apr 26, 2008 at 11:07 AM
MERLIN2021
  • 17,250 POSTS
To: merlin2021
Posted: Sat Apr 26, 2008 7:01 pm
Subject: 91 ply.sundance
i have ALOT of oil in my radiator and car runs hot.is this a head/head gasket problem or could it also block or somethig else ???? please help thank you
Reply: I agree with BMRFIXIT!
Apr 26, 2008 at 12:56 PM
BMRFIXIT
  • 19,053 POSTS
If its over heating :
1. oil in the coolant will cause thermostat to malfunction (if you let it over heat you will cause a head gasket failure )so
2. don’t over look head gasket and do the test if pass
3. flush coolant system and replace thermostat
4. check tranny fluid if milky
5. flush tranny ATF
6. change tranny fluid and filter
7. change radiator
check tranny cooler line and pressure
Apr 26, 2008 at 2:05 PM
