1993 Plymouth Acclaim
1993 PLYMOUTH ACCLAIM
KIMMIE1010
I have a 1993 plymouth acclaim that I have replaced the starter, catalytic converter, new battery, and major tune up done on in the last 2 weeks. But it is still hestitating and shutting off, and still seem to be lossing power. Will a OS/2 sensor cause theses problems, or is it something else? [/b]
The car has about 147, 000 miles on it, and the fuel filter has been replaced.
How do you get the codes off this type of car; or is the codes what lights are on when the problem happens? If so, the engine light is on for about 15 seconds then it goes out.
Feb 17, 2006 at 9:03 AM
PEPPERMRJ
  • 1,158 POSTS
How many miles? Try some fuel injector cleaner in a couple tanks (chevron with techron) and a new fuel filter. O2 is possible but so is a lot of other things. Are there any lights/codes lit?
Feb 17, 2006 at 10:09 AM
