1992 Plymouth Laser
ADAM71580
1992 Plymouth laser 4 cyl
how can i get the car to flash the codes without putting it on a computer
Apr 22, 2008 at 8:23 AM
MERLIN2021
  • 17,250 POSTS
Turn the key from off to on three times, on the fourth one leave it in the on position, count the flasshes...22 would flash as 2 blinks, then a short puase, then 2 more blinks...if several codes are stored, the pause is longer between codes, code 55 will be the last code...do this and post all codes found...
Apr 22, 2008 at 8:24 AM
