1991 Plymouth Acclaim Idle Adjustment
1991 PLYMOUTH ACCLAIM
112,000 MILES • 4 CYL • FWD • AUTOMATIC
FREEDOM2831
How do I adjust the idle speed?
Jun 14, 2010 at 5:32 PM
CARADIODOC
  • 34,383 POSTS
Hi freedom2831. Welcome to the forum. The idle speed is not adjustable. What is the symptom or problem? Is the idle speed too fast or too low? Does the engine stall at stop signs? If so, was the battery recently disconnected or run dead?
caradiodoc
Jun 14, 2010 at 10:40 PM
FREEDOM2831
The idle speed is too slow. The engine sometimes stalls at stop lights unless I shift into neutral. After the engine is completely warmed up, the oil light comes on at stop lights if I don't shift into neutral. The battery was recently replaced.
Jun 15, 2010 at 2:30 AM
CARADIODOC
  • 34,383 POSTS
Dandy news. The Engine Computer loses its mind when the battery is disconnected and has to relearn minimum throttle. To do that, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals. The high manifold vacuum for that long is the signal for the computer to memorize the voltage from the throttle position sensor. From then on, whenever it sees the same voltage, it will know your foot is off the gas pedal and it has to be in control of idle speed.
Sorry for the delay in replying. My Verizon e-mail system keeps going down, often for a day at a time. Without e-mail, I can't get the automated messages that direct me to your last reply.
caradiodoc
Jun 15, 2010 at 10:08 PM
