1991 Plymouth Acclaim 91 Plymouth Acclaim - lousy gas milea
PAULSGROUP
  • 1991 PLYMOUTH ACCLAIM
  • 4 CYL
  • FWD
  • 45,000 MILES
When driving the car before the car gets to operating temperature, the car has essentially no acceleration no matter how much I press the accelerator. It is sorta like the old days when I forgot to pull out the manual choke on a cold day.
In addition, I only get about 110 miles on a 12 gallon tank of gas.
Monday, May 17th, 2010 AT 6:58 PM
RACEFAN966
  • 5,029 POSTS
Ok so lets see what we can do here. Do you have a digital multi meter? If so then when the car is cold (before you start it) ohm the Temp sensor, just simply unplug it and ohm it. Now get back to me with the ohms and the air temp at the time you test it. Also check the air filter make sure it isn't dirty. Also how long has it been sense it had a tune up ie: plugs cap rotor and wire? Get back to me and we will go from there.
Tuesday, May 18th, 2010 AT 8:59 AM
PAULSGROUP
Where is the Temp Sensor?
Wednesday, May 26th, 2010 AT 10:45 PM
RACEFAN966
  • 5,029 POSTS
Ok it is near or on the thermostat housing. It will have a two wire connector to it. Simply unplug it and do this when the engine is cold and get me the ohms and the air temp at the time you test it. With that I will look up the specs to see if it is good or not.
Thursday, May 27th, 2010 AT 12:08 PM
PAULSGROUP
I had a local mechanic check it out. He replaced the Oxygen Sensor and the car runs fine, now.
Monday, May 31st, 2010 AT 11:12 AM
RACEFAN966
  • 5,029 POSTS
Wow thats funny if the coolant temp sensor checked out good that was the next test we were going to do. Anyway thats great that it is doing fine. If you have any other questions just ask.
Tuesday, June 1st, 2010 AT 8:46 AM
Related Engine Low Power Content
