1995 Plymouth Acclaim Plymouth acclaim wont accelerate or d
1995 PLYMOUTH ACCLAIM
50,000 MILES • 4 CYL • FWD • AUTOMATIC
SHORTSTOUGH7117
  • 5 POSTS
My Acclaim wont accelerate i have changed the fuel filter the transmission is ok its not the speed sensor or the tps or manifold pressure it just seems to start ok when in park and i push the gas it revs up like it always has but when in drive it acts like its just not firing right its almost like the whole engine stops working
May 27, 2010 at 5:17 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 27, 2010 at 10:39 AM
AADDDAAAAMMMMM
Kick down on transmission stuck, cable for kick down is connected to the throttle. When in gear the stuck kickdown will not allow the gas pedal to be fully depressed.
Sep 16, 2010 at 3:45 PM
