1990 Plymouth Acclaim Won't stay running
1990 PLYMOUTH ACCLAIM
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
INNEEDOFHELP1
I have a 1990 Plymouth Acclaim it starts but won't stay running for long what is the problem?
Dec 5, 2009 at 3:47 AM
JDL
  • 16,098 POSTS
Welcome to the forum, how long since a tune-up? Spark plugs--wires-- all filters-- fuel pressure ok? Check for codes. You should be able to get some mil codes by cycling the ignition switch. You turn the key just till the dash lites come on, no further, cycle the key, on--off, on--off, on, then the check engine lite starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Dec 5, 2009 at 3:57 AM
