HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Venture
Engine
Symptoms
Overheat
SPONSORED LINKS
Engine Overheating?
PREV
1
2
3
NEXT
EARL.OWENS
MEMBER
Yes, I checked all the pullys on it and everthing is tight and nothing is broken or loose
Friday, August 21st, 2020 AT 11:51 AM (Merged)
SATURNTECH9
MECHANIC
See if the belt tenisoner has plenty of tension?Also if all the pulleys are lined up with each other?
SPONSORED LINKS
HRALI6
MEMBER
1 POST
2000 CHEVROLET VENTURE
6 CYL
FWD
AUTOMATIC
Chevrolet venture 2000 overheat when stop cooldown when it run otherwords idling overheat run the gage go to cooldown?
FIXITMR
MECHANIC
Is cooling radiator fan working when hot?
MECHANIC
Check the thermostat, coolant level and cooling fan
SPONSORED LINKS
PREV
1
2
3
NEXT
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Engine Overheating? Cooling Fan Starts Working Too...
I Found A Problem. The Cooling Fan Starts Working Too Late;only When The Temperature Needle Goes Up Near "red Color Hi" Does It...
Asked by
Thomas Heo
3 IMAGES
1999
CHEVROLET VENTURE
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Engine Overheating?
Working On A Overheating 2002 Chevy Venture 3400. Cooling Fans Do Not Come On. Fuses Are Good And The Fan Motors Themselves Are In Working...
Asked by
j.stieg
3 IMAGES
2002
CHEVROLET VENTURE
What Causes My Van To Overheat?
It Was Overheating, So I Bought And Had Replaced A New Thermostat, Also A New Water Pump. The Motor Isn't Feeling Hot, But Yet The Meter...
Asked by
MotherOf2
1997
CHEVROLET VENTURE
2001 Chevrolet Venture Lack Of Power, Misfires
2001 Chev Venture Van 3.4l A Little Hesitation When Accelerating From Dead Stop. When Accelerating To Highway Speeds, Especially Uphill...
Asked by
Maghnuis
2001
CHEVROLET VENTURE
2001 Chevy Venture Won't Start
My 2001 Chevy Venture Won't Start. Engine Light Was On For About 1 Month. No Problems Starting Until The Day It Just Wouldn't Crank....
Asked by
tiing69
1 ANSWER
2001
CHEVROLET VENTURE
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
