Pickup cuts off when coming to a stop - Vibrates and cut off- runs good otherwise
46,000 MILES • V8 • 2WD • AUTOMATIC
CHESTER7
Dodge ram pickup 1988 runs good, starts good, but vibrates strong and then engine cuts off every time I come to a stop, have to re crank to go on...Had 2 different fuel pumps on it already, no help...Can you help me???
Jul 22, 2014 at 6:36 AM
  • 110,251 POSTS
Have you checked for vacuum leaks? Have you checked the ISC actuator? Have you checked it for trouble codes?
Jul 22, 2014 at 1:01 PM
CHESTER7
They put a new Idle celoniod on it to start with - have cked for Vacuum leaks no leaks NOW THEY ARE CKING THE ECM (Engine Computer Module) -Truck was wrecked 6 months age on the left drivers side the fender where the ECM is located they are thinking this might be the problem - Is there a way the ck it without having to replace it first to see if not damaged?
Jul 22, 2014 at 10:29 PM
  • 110,251 POSTS
Before I try to answer that, tell me... do you have the truck at home where you can get to it?
Jul 23, 2014 at 12:19 PM
CHESTER7
No it's at the Dodge Place..They Are looking into the ECM - It's under the Driver side front fender the truck was wrecked on that side and repaired but same ECM unit was put back in the finfer well...So I'm not sure they have a way of cking to see if ECM unit is ok or not...Thanks for all you help...Blessings
Jul 23, 2014 at 10:31 PM
  • 110,251 POSTS
Let me know what you find out from them.
Jul 24, 2014 at 11:23 AM
