Hi I have my instrument panel take out, i replaced the ignition cylinder with a used on that came with the key, i also want to replace the Anti-theft deterrent relay while the instrument panel is out, but i cant fine the relay and i know it exists because i bought the relay from a local parts store, so is it behind the radio ?? or is it behind the glove compartment ?? or maybe near the steering column ??
also could u give me the exact procedure with timing to relearn the password, the ignition cylinder, and the housing for the cylinder have been swapped out, so i need to relearn, have seen things about keeping the key in run postion for 10 minutes, a repair dude also told me to flip it back to the off after the 10 minutes is up and then repeat that,
really need the exact procedure to get the Impala to relearn,
hope u r fine, it is really nice here in NE, thx for the service u provide, c u
Sep 15, 2014 at 5:02 AM
