either bypass or eliminate the "Passkey" system
140,000 MILES • 6 CYL • FWD • AUTOMATIC
QX4
  • 11 POSTS
Is there a not too complicated way to either bypass or eliminate the "Passkey" system. I believe this to be my problem. At times vehicle thinks I am stealing it. Sometimes it will not start in "Park" and when it does start in "neutral" it runs for approx. 5 seconds. Security light comes on and vehicle goes to "shut -down" mode. Any help would be appreciated
Thanks
Sep 15, 2008 at 10:31 AM
RHALL77
  • 3,361 POSTS
i would not suggest bypassing it. if it is not starting tey this, turn the key off for 30 seconds. crank the engine real quick and leave the key on. watch for the security light to blink. let it sit until the light quits blinking. about 10-30 min. when the light goes out, turn the key off for ten seconds then try to start. it this works you need a new pass lock sensor
Mar 12, 2021 at 1:28 AM
