2014 Dodge Caravan No Charge
Rechecked wiring with alternator connected and battery terminals disconnected:
Alt pin 1 to PCM C2 pin 2: 0.1 Ohms,
Alt pin 2 to PCM C2 pin 40: 0.1 Ohms,
Alt pin 1 to gnd: 2.7 Ohms,
(C1 pin 50 = gnd = batt black lead)
Alt pin 2 to gnd: climbs - 2k to above 10k...just keeps climbing.
With Alt disconnected:
Alt pin 1 to gnd open
Alt pin 2 to gnd open
PCM C1 pin 96 to red batt lead: 0.1 Ohms,
Large red Alt lead to red batt lead: 0.5 to 1.0 Ohm.
I'll have to try again tomorrow.
(or the Alt conn socket to the Alt pin 2, but it looked solid).
I should be able to get back on it today.
Thanks so much for the diagram, circuit operation description and PCM pinout. Huge help!
Alt pin1 to C2 pin 2: 0.1 Ohms.
With 12.7Vdc put on Alt pin1, C2 pin2 lights the test light.
Alt pin2 to C2 pin40. 0.1 Ohms.
12.7Vdc to Alt pin2, C2 pin40 lights the test light.
PCM C1 pin 96 12.7Vdc & lights the test light.
I'm finally convinced that this wiring is good.
I found a Remy tech service bulletin on Chrysler charging systems that has more info on these alternators, (at autoprollc.com website menu under Service Resources under Technical Bulletins). It turns out the sense output (alternator pin 2) is a Kelvin sense circuit that should have no current on it, but it does have a 2.4k Ohms resistor in the alternator to protect it from shorts to ground. That's where the 2.333k Ohms came from, and the voltage drop on alternator pin2 when the engine is started.
I'm not convinced the new PCM is good, but apparently there is a 5V turn on voltage to the EVR circuit when the PCM determines it should be turned on.
I haven't found the inputs the PCM requires to determine that the ignition is on and the engine is running. I haven't heard of any other requirements. Thanks for your help.
Yes, this sounds like the PCM itself. The fact you got it to work with one of the others tells me that is the use along with all your checks.
Did you use the exact same number PCM from your original?
Voltage checks on the lines are not accurate as there is pulse width modulated signals sent from the PCM.
That is why you need a scan tool to monitor what the ECM is commanding.
Suggested Repair
Use a scan tool to monitor the PCM/ECM alternator field (EVR) command and internal load detection; ordinary voltage checks are unreliable because the field signal is pulse-width modulated. Wiring and the alternator tested good, and another PCM did command charging, so if the scan tool shows no field command, replace or reprogram with a known-good PCM of the exact original part number.
Conversation Summary
The owner of a 2014 Dodge Caravan requested PCM pinouts while diagnosing a no-charge condition. After replacing the battery, alternators, and PCMs, continuity and power feeds between the alternator and PCM checked good. Applying battery voltage to alternator pin 1 made the alternator charge, proving the alternator works. Experts explained the field circuit is PWM-controlled and recommended a scan tool to see what the PCM commands; one concluded the PCM itself is the likely fault because another unit did turn the alternator on.
