How to disassemble PCM connector? I want to tighten the female pins.
Jul 22, 2018 at 2:49 AM
✓Experienced Mechanic
Good afternoon.
You do not need to disassemble the connector. you can just get a set of eyeglass screw drivers and use the small one to tighten up the pins. I ahve done this for years.
you need a special pin remover to remove the pins. you can get it at a parts store if you still feel you need it.
Jul 22, 2018 at 5:51 AM
WEINER
MEMBER
So do I need to insert screw driver inside the hole and pull down on the tab?
Jul 22, 2018 at 7:49 AM
Yes, use light to see where the tab is located and which way it has to move.
