passenger side doors electrical fault
100,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MICKBARR
The front and rear passenger doors do not lock. The windows and the mirror does not work on that side of the car. If I try to lock the car the drivers side and boot lock, but then it immediately opens. I have checked the wiring in the door and in the plugs where the wiring goes from the door to the bulkhead and all are okay.
Many thanks.
Mick
May 19, 2016 at 5:40 PM
  • 55,616 POSTS
Hey Mick,
It sounds like you have a lock actuator that has gone bad, also check the window motor for power I have seen were if that side of the car was subject to water it will cause everything on that side to go bad.
Let me know what you find,
Here is a link that will help you test the window motor.
https://youtu.be/HBFBcJrdym4
Best, Ken
May 21, 2016 at 12:38 PM
