part were radiator hose connects to mainfold
4 CYL • AUTOMATIC
ERIN39
The hose that connects from the radiator reservoir to the intake manifold the piece that holds the hose in place at the manifold broke in half now when i try to clamp the hose to it it falls off cause that plastic piece. NEED help
Apr 19, 2014 at 9:36 AM
SATURNTECH9
  • 30,869 POSTS
If you have a plastic nipple on the intake manifold then you have a sl21 not a sl1?Is this correct?If so that nipple is part of the intake manifold. I have seen ebay sells a repair kit you have to remove the manifold and cut out that part of the manifold. The repair takes the place of the part you cut out and its metal instead of plastic.
Apr 19, 2014 at 10:33 AM
