1993 Saturn SL1
185 MILES • 4 CYL • 2WD • MANUAL
MCKENDREE
How do i add my coolant. I can only find the overflow does my car have a radiator cap. It has a small leak and i have added stop leak through the plastic overflow and filled it to the top
Oct 31, 2010 at 4:47 PM
SATURNTECH9
  • 30,869 POSTS
Your radiator fill is the tank over by the washer fluid with the screw on cap.The screw on cap it has is your radiator cap.The most common place's for it to leak are the radiator right below the upper radiator hose or the water pump.
Nov 1, 2010 at 4:24 AM
