Panel gauge not showing what gear transmission is in
60 MILES • 2.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
PAT LABIANO
The panel gauge doesn't show were your transmission gear is.
May 28, 2019 at 2:10 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, this vehicle isn't offered in the US, so I have very limited technical information related to it. However, I will try my best to help. On vehicles today, there is a component on the transmission called a range sensor. This sensor is what determines what gear the vehicle is in as well as sends a signal to indicate the selection on the instrument panel.
The sensor is usually located on the transmission where the shift linkage connects. Check that to determine if something is loose or damaged.
I wish I could offer more information, but let me know what you find.
May 29, 2019 at 11:28 AM
