Service engine soon light is on?
2CP-ARCHIVES
  • 4,540 POSTS
  • 1998 FORD E-SERIES VAN
  • 80,000 MILES
ENGINE LITE ON-- CODE READER SAYS PO171 AND PO174. WHAT DOES THIS MEAN?
Tuesday, July 28th, 2020 AT 10:40 AM (Merged)
Lean codes.
Could be vacuum leak, pcv valve, mass air flow sensor or low fuel pressure. You need to have the long term trims monitored to help with determining the failure
TERRY59
  • 1997 FORD E-SERIES VAN
  • 6 CYL
  • 170,000 MILES
The "service engine light" is staying on my 1997 Ford Econoline 150 Van.
CARADIODOC
  • 34,354 POSTS
That means the Engine Computer detected a problem and set a diagnostic fault code in memory. Many auto parts stores will read those codes for you for free. That will get you into the circuit or system with the problem, not necessarily the defective part.
GLENN SCOFIELD
  • V8
  • 144,000 MILES
Service eng light is on how to turn off
Tuesday, July 28th, 2020 AT 10:41 AM (Merged)
  • 31,937 POSTS
You will have to get a scan done, as you will first have to repair the fault that the code indicates, if you just clear the code it will re set again.
Mark (mhpautos)
