Hello, I desperately need help. So I have used a scan tool and popped up p1381 Camshaft Position Sensor 1 circuit malfunction and MAP sensor. I have replaced the distributor rotor only cause the cap is good, I have replaced the CKP/TDC crankshaft position sensor and replaced my balance shaft belt and I have seen my timing belt is new as well as the water pump. So those parts was good and use scan tool again and pops up open again with P1381 Camshaft Position Sensor 1 circuit Malfunction. So I am thinking is it talking about the camshaft itself connect to the camshaft pulley under the valve cover or is it a small sensor I need to replace? Please help my money is bouncing everywhere and I just want to fix it and pass my emission test. :( All I need to know is what is that part causing that check engine light so I can clear it and pass my emission. Please help me. :(
Sep 1, 2018 at 1:47 AM
