P0171 code
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
MELODY KEECH
Cannot fine problem new 02 sensor new fuel filter new coil paks, spark plugs, new map sensor and oil change.
May 2, 2017 at 1:44 PM
STEVE W.
  • 15,415 POSTS
P0171 - System lean Bank 1 - Put a scan tool on it and watch the fuel trims. See if the issue is a vacuum leak (most likely), bad purge valve or other air leak by testing those as you watch the fuel trims. Check the fuel pump pressure as well, a weak pump can cause this.
Basically you need to actually see what the various sensors are sending to the ECM to diagnose this.
Coil packs and plugs will not cause a lean code. Misfires caused by those could however cause a rich code.
May 2, 2017 at 3:30 PM
