P0171 code has been showing up (System too Lean)
138,000 MILES • V6 • 2WD • AUTOMATIC
TLARMA
For a little over a month, P0171 (System to Lean) code comes up. My brother has cleaned the throttle and the MAF. It then worked fine for a few weeks, then the code came up again and the sputtering started. He took it to O'Reilys Auto Parts. They had said since you removed the throttle and put it back in, it would need to retrain itself. He then removed it again and cleaned out other parts in the car. Just the other day, my car started sputtering again in the morning. It runs fine the rest of the day. Also, when I was out of town the other day, my car sat for about four days with a low tank of gas. When we were traveling on the highway, my reduced power engine light came on. Once I filled up with gas it was fine. i am just trying to see what could be the problem. Do I need a new O2 sensor, a change of the manifold gasket, fuel injector cleaning? Not sure. The car is good to drive, but would like to fix this problem.
Jul 6, 2016 at 12:41 AM
HMAC300
  • 48,601 POSTS
it does not need to retrain it does it while it is driving and computer does that not tbi. check fuel pressure with a gauge auto parts rent it.
Jul 6, 2016 at 1:08 AM
TLARMA
Thanks. My brother is out of town. The vehicle seems fine to drive. I am okay driving it for now.
Jul 6, 2016 at 1:16 AM
  • 55,837 POSTS
Hi TLARMA,
It sounds like you could need spark plugs, if the engine misfires it will set a code for the lean p0171
Here is a couple of guides to help you
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
and
https://www.2carpros.com/articles/how-to-change-spark-plugs
Let me know what you find out
Best, Ken
Jul 7, 2016 at 9:36 AM
RENEE L
  • 1,260 POSTS
Hi TLARMA,
Here is a link to an article from this site that features written instructions and pictures showing and explaining the process of checking the fuel pressure yourself. If you decide you would like do this yourself you can purchase an inexpensive fuel pressure gauge online from sites like Amazon.com.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Jul 7, 2016 at 9:40 AM
