Good morning.
The 16 code is for the crank/cam sensor alignment. If they are not synced together, this code will set.
What it means is the valve timing may be off setting this code. The chain may be worn enough to set this code. You need to have someone check the timing chain to be sure it is not worn out.
https://www.2carpros.com/articles/how-a-timing-belt-works
132 code Yes, I would use an NGK sensor
P0132
Descriptor
O2 Sensor 1/1 Voltage High
Probable Causes
Oxygen (O2) Sensor
Oxygen Sensor (O2S) Above 3.7 Volts
Oxygen Sensor (O2S) Return Circuit Open
Oxygen Sensor (O2S) Signal Open
Oxygen Sensor (O2S) Signal Shorted to Voltage
Powertrain Control Module (PCM) Return Circuit
Powertrain Control Module (PCM) Signal Circuit
I would have someone with a scan tool monitor the voltage at the O2 sensor. It could be a broken wire, bad connection, or PCM failure.
It needs to be checked. You can replace the sensor but that may not fix it as most of the possibilities revolve around wiring issues.
Oct 16, 2018 at 9:06 PM
