Overheating
175,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
BENNYB43
My car listed above (LX) was overheating periodically. It wouldn't overheat right away. I keep adding water about once a week and that seems to prevent overheating. I changed the thermostat to see if that would fix the issue, but still overheats. Next, I added "stop leak", this stopped the water leak, but now it overheats faster after driving about 2-3 miles. With the stop leak it appears no water is leaking from anywhere. I can also confirm the radiator fans are working and that is not the issue. I also replaced the water pump about 2 years ago and don't think that is the issue either.
I think using the "stop leak" was the wrong move as the overheating seems worse now.
Any idea what I should do next to stop the overheating?
Aug 29, 2021 at 11:38 PM
  • 110,248 POSTS
If the thermostat is new, the stop leak may have caused an issue, but there could be a different issue.
The first thing I would try is to drain and flush the cooling system to make sure there isn't a partial blockage in the radiator or engine block. Here is a link that shows how that is done:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Also, prior to the stop leak, could you tell where the leak was coming from?
Next, if the flush doesn't help, you bled the cooling system of air, and the system is full with no leaks, we need to check for a possible head gasket issue. Take a look through this link. It explains what to look for.
If nothing is found there, I need more information. For example, are there any diagnostic trouble codes stored in the computer? Does the vehicle run normally prior to overheating? Is the radiator (front) restricted in any way? Are there any odd smells, sounds, characteristics of the vehicle you notice?
Aug 30, 2021 at 12:39 PM
