Overheating and now shut off and will not start
145,031 MILES
WENDY RHEA
My gauge went all the way to the "H". I pulled over turn the car off the car there was no steam coming out. It did take eight bottles of water. I had to buy case of water. Then I drove it and the gauge started going up like when I was in the highway doing sixty. I pulled over the gauge went down, then I drove it doing probably no more than thirty miles an hour and it was fine and then all the sudden it shut off. I am sitting here right now and it will not start. It shut off when I was driving it.
Jul 11, 2018 at 9:04 AM
  • 55,746 POSTS
It sounds like the engine shut off for one of two reasons. Either the engine is severely overheated and it has lost compression or the computer has detected the engine overheating issue and has shut it down. Let's start by running the codes which will confirm the detection by the computer and shut down the engine. Can you send a video of the engine turning over? I can tell from that what the problem is. You can upload it here.
Also lets run the codes.
Cheers, Ken
Jul 14, 2018 at 8:11 AM
