Overheating
160,000 MILES • 2.7L • 4 CYL • 2WD • AUTOMATIC
LPL111111
- While driving, the interior car heat goes on and off.
- The temperature gauge goes up and down.
- As soon as the interior car heat comes back up, the radiator temperature gauge goes down.
- The overheating problem is mostly when idling.
Last year (twelve months ago), the same-same problem occurred and i changed the thermostat and it never did this problem again, until now.
- Now today, I changed the thermostat and still happening.
- Would there be a bubble of air, inside the system, preventing circulation or something else?
- Could i have put the thermostat incorrectly? or upside down?
- if i put CLR calcium deposit remover in the radiator, would that maybe help circulation or damage metal integrity?
Dec 18, 2017 at 2:54 AM
Good afternoon my name is Roy and I will assist.
Yes, it may have an air block.
Possible causes:
1. low coolant level
2. air in system
3. bad thermostat
4. restriction in the system
How long has it been since you replaced the thermostat?
Dec 19, 2017 at 12:33 AM
LPL111111
The same day as i posted my question.
Today, i added CLR to dilute possible calcium deposit, in the radiator, that might obstruct coolant flow.
i will have a drive today to see if it has improved temperature gauge readings. I also added Teflon oils, into the pan, to protect my engine in case of overheating.
Dec 19, 2017 at 1:05 AM
Never use any additives in any systems. They contain all the needed protective's already.
The oil additive will not protect the engine at all. When you have a head gasket failure, the coolant in the oil attacks the babbitt material in the main and rod bearings. There is no product to prevent that.
Dec 19, 2017 at 1:38 AM
