Overheating at idle is a constant problem
130,000 MILES • 4WD • AUTOMATIC
SHAYD137
I have had car for two years. It will act up at times and happen every time I drive then it will stop happening for months. I have had the thermostat replaced and had the car looked at several times. The only thing I notice is after it overheats and I shut the car off the fans (I’m assuming) are very loud and remain on for a while after car is off.
Jul 17, 2019 at 12:22 AM
Good afternoon,
Are there any codes stored in the system?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
How old is the coolant? If you have the wrong mixture, it will do this.
Does it cool right off when you go above idle?
Has the water pump been checked for flow?
Jul 1, 2021 at 6:04 AM
