Overheating
165,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
ANDRES FLORES
  • 5 POSTS
My wife’s truck was overheating so I thought it might be the thermostat so I replaced it, but after she drove it the next morning to work it began to overheat again. any thing else I should check that could possibly cause it to overheat?
Jan 18, 2018 at 10:10 PM
  • 55,748 POSTS
If the coolant is full i would drain a little out and then test it for a blown head gasket which these vans had a problem with.
Here are two guides to help us find out what the problem is:
and
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Cheers, Ken
Jan 20, 2018 at 5:12 AM
ANDRES FLORES
  • 5 POSTS
I checked it out there were no signs of blown head gasket. is there anything else that you think it could be?
Jan 21, 2018 at 7:56 AM
  • 55,748 POSTS
When the engine is overheating do you here the clutch fan kick on it should sounds like an airplane taking off next to you. If not the fan clutch is bad nit pulling air through the radiator.
Here is a video to show you how to remove the fan clutch.
https://youtu.be/N_-MLVlBHk8
This guide can help as well.
https://www.2carpros.com/articles/fan-clutch-removal
Cheers, Ken
Jan 22, 2018 at 9:56 AM
ANDRES FLORES
  • 5 POSTS
I see it spinning but I do not believe it is kicking on
Jan 22, 2018 at 11:33 AM
  • 55,748 POSTS
ahh! that will do it my friend lets replace it and see what happens. It should fix it.
Jan 23, 2018 at 1:48 AM
ANDRES FLORES
  • 5 POSTS
So I replaced the fan clutch and it still overheated so I also decided to replaced the radiator cap and it stopped overheating thank you for your help
Jan 30, 2018 at 11:54 AM
  • 55,748 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jan 31, 2018 at 2:56 AM
ANDRES FLORES
  • 5 POSTS
So I seeemed to be wrong it overheated again this morning any clue of what else it could be
Jan 31, 2018 at 4:13 AM
  • 55,748 POSTS
Back to head gasket did you do the chemical test? A head gasket can be blown even though there is no coolant in the oil.
Jan 31, 2018 at 4:25 AM
