1995 Chevy Trailblazer Overheating?
JLAKE88
  • 1995 CHEVROLET TRAILBLAZER
Engine Cooling problem
1995 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic
I have a 95 Trailblazer, when it reaches about 185 degrees or so it will start running rough and die, in order to get it to start again the engine needs to cool compleatly down-we've tried going through the fuel system, but nothing helped. Any ideas on what might be causing this?
Saturday, October 16th, 2010 AT 6:50 PM
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sunday, October 17th, 2010 AT 2:14 AM
