I replaced the thermostat, radiator censor, and fan relays for hot and cold radiator fans.I may have over filled the transmission fluid before all this? Could that have caused the problem? I was told it could be either the water pump, or a blown head gasket. It's fine running idle but as soon as I drive it a few blocks it over heats. I only paid a 1000 dollars for the car. Is it worth trying to get it fixed? I don't know if I should replace the water pump or not?
SPONSORED LINKS
Friday, January 24th, 2014 AT 3:05 PM
