1995 Chrysler LHS overheating
139,000 MILES • 6 CYL • FWD • AUTOMATIC
JSTACHIK
What would cause my engine to overheat severly one day but not the next time it was driven.
It seems like it's an intermittent problem, but on occassion, it happens back to back.
Thank you for any advice.
May 29, 2009 at 11:18 PM
  • 75,988 POSTS
Replace the thermostat and see what happens
May 30, 2009 at 1:16 AM
JSTACHIK
Thanks! That's the frist thing I tried before I asked for help. I've since then replaced a lower hose, flushed &* refilled. Bled system, verified waterpump was still good, (just replaced last yr.), checked fans, air cleaner, so 0n & so On!!! No leaking heater core, exhaust clean & no moisture, oil very clean & proper, (has been changed every 3,000 since late 95.) No oily or trans fluid in coolant drained or at any trime. Fan clutch working fine, belts just replaced last yr. Radiator not leaking, cleaned of debris always, & no hot or cold areas unevenly. Cat converter fine. No timing problems, or vacumn leaks detected.
About as thorough check as I can do with some help of course. I'm a 53 yr old woman. No to bad huh?
But it's getting the best of me. Now I need to know where I should go from here & I would greatly appreciate any more advise or suggestions.
Thank you for your quick reply.
May 31, 2009 at 4:00 PM
  • 75,988 POSTS
Could be air in the cooling system try bleeding it
Jun 1, 2009 at 10:17 AM
