runs but when stopped it will not start up again
150,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
AHAMAD SUJEER
hi,
my car shows a starting problem, in the panel it shows check.
once it starts it runs smoothly, but when it stops it will not start again.
please advice.
Feb 17, 2017 at 8:28 AM
STEVE W.
  • 15,421 POSTS
Many things can cause a no start. As the check engine light is on, take it to a shop and have them read the code(s) stored. That would give you a direction to start from.
Feb 17, 2017 at 9:05 PM
AHAMAD SUJEER
the problem is relatedd to sensors , i changed the crank shaft position sensor , and it was not the reason and i check the ignition control unit situated under the ignition key , it was faulty and the cause of the issue , but the major problem is unavailability pf this part .
my advise is optra is a good car but never try to buy it , if you have problems its parts are not available
its the common issue with all Chevrolet cars , so is it better to stay away from Chevrolet cars?
Feb 18, 2017 at 5:24 AM
STEVE W.
  • 15,421 POSTS
The Optra is not a real Chevrolet, it is a Daewoo Lacetti made in South Korea. GM had a deal with Daewoo at the time to sell re-badged cars in countries that GM did not sell a lot in.
As for parts availability, every brand out there has vehicles they do not support. Especially ones that were re-badged units.
Feb 18, 2017 at 6:38 AM
