engin problem , any help here
OPEL
MAJDIY
  • 5 POSTS
Hi everybody
Iam happy to find you .
I have a car 1988 opel kadet , engin size 1600CC
Iam having a bad problem with my car engin , when the engin is cold its shiver and not stable , its stay like this after the heat height then it back stable , i did try to repair manythings like the engin basments but not solved .
I hope to find here any sugesstion or to know whats the problem.
Thanks
Regards
Apr 9, 2007 at 1:52 AM
MAJDIY
  • 5 POSTS
ok i make donation :)
i hope someone will take care of my problem bcoz iam sick from it .
Apr 9, 2007 at 2:19 AM
BRUCE HUNT
  • 3,754 POSTS
Engine basements - are you referring to the motor mounts? I would suspect them. Given the age of the vehicle, they could be drying out and weak. They may look fine but don't let that fool you.
I would check the egr valve and the pcv.
What you need to determine is whether this is a engine performance problem or a mounting issue.
Apr 9, 2007 at 4:30 AM
MAJDIY
  • 5 POSTS
hi
thank you for your replay .
iam sorry sir , iam not that good in cars english words.
the motor mounts i replaced them with new one but the problem didnt solved the same .
the problem not performance , the motor is strong , but as i told you whenever the motor cold its shiver alot .
Regards
Apr 9, 2007 at 4:57 AM
BRUCE HUNT
  • 3,754 POSTS
I would check the EGR valve and the PCV.
Not a problem, I think I understood you just fine.
Apr 9, 2007 at 9:04 AM
MAJDIY
  • 5 POSTS
Hi
Thanks
Can you please show me a picture for the EGR valve and PCV , iam sorry iam not sure what they mean in my language , if you have a picture or some explain to understand , and i will check them soon
Regards
Apr 9, 2007 at 9:28 AM
BRUCE HUNT
  • 3,754 POSTS
Our books do not cover the Opel but here is a link to a website with generic information and diagram about the EGR valve.
Apr 9, 2007 at 9:51 AM
MAJDIY
  • 5 POSTS
Thank you very much :)
Apr 9, 2007 at 10:50 AM
