Not starting properly
215,000 MILES • 1.7L • 4 CYL • TURBO • 2WD • MANUAL
TERSIUS NOUNES FERREIRA
Hi there, i have the vehicle listed above Gamma 1.7 dti. It is struggling to start like there is a compression problem, but there isn't not. sure if it's the injectors or the injector module. can you please assist me with this problem?
0792628242
Aug 16, 2021 at 4:53 PM
Unfortunately we don't have a manual on this vehicle as it is not offered here in the USA but I am sure that we can figure something out on this.
What makes you believe that the injectors are the issue? Are you able to use starter fluid in the intake in order to get the engine to start?
Have you checked the fuel pressure to find out if we have a fuel delivery issue?
https://youtu.be/dCjmRL3p4Cs
Lastly we need to know if there are codes in the system which will help figure out possible issues.
Please run through this info and let us know a little more detail on what is happening when you try to start the vehicle and we can go from there.
Thanks
Aug 18, 2021 at 11:49 AM
