1996 Opel Astra
FREESMAN
  • 1996 OPEL ASTRA
Engine Cooling problem
1996 Opel Astra 4 cyl Front Wheel Drive Manual
Should a cooling fan driven only by electric motor (no belts) always be on or does it rely on the thermostat for control?
Monday, February 2nd, 2009 AT 2:26 PM
  • 31,937 POSTS
Hi there,
Engine cooling fans rely on a separate temp sensor in most case, this is basically a heat switch that turns the fan on and off at a pre set temp, they should not be on all the time, If the A/C is on and there some cars will run the fan then as well all the time.
Mark (mhpautos)
Monday, February 2nd, 2009 AT 3:31 PM
