1996 Opel Astra Could not start
257,000 MILES • 4 CYL • FWD • MANUAL
SIBUSISO.MTHIMKHULU
What could be a problem the stator is ok could not ignite please help will it be fuel injector or petrol pump ?
Jul 30, 2008 at 6:16 PM
  • 75,988 POSTS
Do below to determine if its fuel or igniton problem something has to give then report back your findings.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors
Jul 30, 2008 at 6:22 PM
  • 31,937 POSTS
Hi there,
The first thing to do is check for spark, and fuel pressure and injection pulse, when you know what is not happening we can check a little closer.
mark (mhpautos)
Jul 30, 2008 at 6:23 PM
OPEL PARTS GREECE
  • 131 POSTS
[quote:d6b90fafa6="Sibusiso.Mthimkhulu"]Engine Mechanical problem
1996 Opel Astra 4 cyl Front Wheel Drive Manual 257000 miles
What could be a problem the stator is ok could not ignite please help will it be fuel injector or petrol pump ?[/quote:d6b90fafa6]
fuel pressure?
For more details and help adress to us
OPEL PARTS GREECE
E-mail: alpharm@otenet.gr
Online: Opelparts@hotmail.com
Skype: Opelparts
Oct 3, 2008 at 5:33 PM
