1996 Opel Astra enjine misfire
215,000 MILES • 4 CYL • FWD • MANUAL
MEGIM22
engine misfire and backfire threw the
intake manifold.it has a crank triger and a knock sensor.20seh opel engine
Mar 7, 2010 at 7:19 PM
  • 75,988 POSTS
Do you have a check engine light and when was your last tune-up??
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors
Mar 7, 2010 at 8:10 PM
