Only drives in reverse
2004 LAND ROVER FREELANDER
91,000 MILES • 2.5L • V6 • 4WD • AUTOMATIC
IOWNME
  • 6 POSTS
I am looking at this car tomorrow to maybe buy it as it is very cheap.
It only drives in reverse.
I am a good mechanic and have tools.
Any ideas what is going on?
Sep 16, 2018 at 11:00 AM
STEVE W.
  • 15,345 POSTS
That should be a Jatco JF506E transmission. They commonly have an issue where they lose reverse but have all the forward gears, to see one the opposite way is rare but not impossible. The most common reason for loss of all forward gears it is a broken retainer clip on, or the outright failure of the low clutch drum.
The same trans was used by VW as the 09A, if you google 09a self study guide 232
you can get a pretty good idea of what you are facing inside.
Sep 16, 2018 at 4:02 PM
IOWNME
  • 6 POSTS
Is a low clutch drum something a home mechanic can buy and install?
Sep 17, 2018 at 12:19 AM
STEVE W.
  • 15,345 POSTS
You will need to get it from a transmission shop or order it online unless you have a commercial account at most of the chain parts stores but it can be purchased. However, unless this is a fix it and flip it fast deal I would probably do a full upgrade on it, they are known for the reverse piston cracking the drum failing and the band failing, you can get all of those parts as an upgrade kit that makes that transmission a lot better.
Sep 17, 2018 at 6:01 AM
IOWNME
  • 6 POSTS
I see information about the reverse piston cracking and that it can be replaced without removing the transmission. Is it possible it has just a cracked reverse piston? Most threads do not mention my symptom, they all have a no reverse condition.
The parts you mentioned are they also all accessible by removing the transmission wind cover?
Sep 17, 2018 at 10:20 PM
IOWNME
  • 6 POSTS
That should "read end cover".
(I have seen a pictorial breakdown of the reverse piston removal and it looks do-able.
Sep 17, 2018 at 10:21 PM
STEVE W.
  • 15,345 POSTS
The reverse piston will cause slipping or poor engagement in all gears, but to lose all forward gears but still have reverse only the low drum is the culprit, or its retaining clip.
Should be able to do all of it through the end cover as it provides the access.
Sep 18, 2018 at 3:43 AM
IOWNME
  • 6 POSTS
Thank you very much.
Sep 18, 2018 at 6:33 AM
STEVE W.
  • 15,345 POSTS
You are welcome. Thank you for using 2CarPros.
Sep 18, 2018 at 10:24 AM
IOWNME
  • 6 POSTS
I usually use specific forums. I am impressed and surprised how good the answers were I got here. I will be back.
Sep 18, 2018 at 10:35 AM
  • 55,399 POSTS
Steve W. is one of our best! Please use 2CarPros anytime we are here to help.
Cheers, Ken
Sep 21, 2018 at 4:39 AM
