transmission is not going in reverse
2004 LAND ROVER FREELANDER
30,000 MILES • V6 • 4WD • AUTOMATIC
NELSON KAYODE
is not reversing and i diagnose it showed transmission fluid temperature sensor malfunction and i attended to it. it is cleared, but still not reversing.
Nov 30, 2016 at 4:43 PM
DOCHAGERTY
  • 9,606 POSTS
What did the inside of the oil pan look like? Sounds like a broken clutch pack
Dec 1, 2016 at 11:19 PM
NELSON KAYODE
i just change the oil. its still clean
Dec 5, 2016 at 12:25 AM
  • 31,937 POSTS
I agree with the Dr Hagerty, it sounds like a mechanical problem, but i would not rule out a faulty actuator, a live data read on the transmission will show if the reverse solenoid is activating, if so i feel it will be a mechanical problem.
Dec 8, 2016 at 4:07 PM
