Everything appears to be normal when the key is inserted into the ignition switch tumbler. The door chime works when it should, the dome light comes on. When the switch is turned to the run position, all the dash lights come on, radio works, etc.
When the key is turned to the start position, there is one click, no crank, and everything electrical goes out. If electrical power comes back, it does so on its own schedule.
I had a Ford dealership test the (six month new) battery, and it is good. I jumped across the starter relay (on the passenger side firewall) - old and new - load terminals, and the same result - one click, no start, everything electrical goes out. This was done with the ignition switch on the "off" position.
I removed the starter, and had it bench tested - good. All positive and negative cable terminals/connectors were cleaned.
The truck has a new battery, new starter relay, starter and solenoid.
Am I missing something obvious, or is it PFM from one of the magic black boxes?
Apr 25, 2018 at 9:15 AM
