1999 Oldsmobile Silhouette Power Steering Not Working
1999 OLDSMOBILE SILHOUETTE
170,000 MILES • 6 CYL • FWD • AUTOMATIC
WINDVESPER
The vehicle was driven about 250 miles yesterday with no issue, but today it turns on fine, gas level is low (light is on), but suddenly power steering isn't working, it's very hard to turn the wheel. Checked power steering fluid - it was up to the cold level, and checked the belt. I did not see any problems with the belt. what else could this be?
Feb 22, 2010 at 6:23 AM
2CARPRO JACK
  • 11,533 POSTS
It may have a stuck poppit valve in the pump or a bad rack and pinion, to verify the pump is good, you will need a pressure gauge to install to verify pressure from pump to rack unit.
Feb 23, 2010 at 8:41 AM
