1995 Oldsmobile Silhouette engine will not start
CJDEATER
  • 1995 OLDSMOBILE SILHOUETTE
  • 6 CYL
  • 295,232 MILES
No spark, no fuel. Coil pack not the problem. Tried 2 others with negative results. What could be the problem? I have checked all the fuses and they are all good. No fuel, no spark!
Thursday, April 2nd, 2009 AT 8:46 AM
JDL
  • 16,098 POSTS
Hello, you might check for an rpm signal. Without that signal you won't have any spark at the plugs or injector pulse. Because there is an oil pressure switch in the fuel pump circuit, once you crank it enough to build oil pressure and the switch closes, the fuel pump will run even without an rpm signal, but, without spark and injector pulse, fuel pressure won't help.
You might check the circuits at the crank sensor.
Thursday, April 2nd, 2009 AT 9:13 AM
