Won't start
SHOVELHEAD
  • OLDSMOBILE
92 cutlass supreme, 3.1, 133, 00 miles.
Car sat for about 2 months, now won't start. Have fuel to shroeder valve and fuel pump times out. Pulled a plug- have spark. It coughs and sputters like it wants to go but won't. It acts just like an older carburated car that's flooded. What does a MAP sensor do? It has no engine codes
Tuesday, November 27th, 2007 AT 6:35 PM
BLACKOP555
  • 10,371 POSTS
Does car fire up with Starting fluid.
The manifold absolute pressure sensor provides manifold pressure information to the engine's ECU and in turn calculates air density and determine the engine's air mass flow rate, which in turn is used to calculate the appropriate fuel flow.
Tuesday, November 27th, 2007 AT 6:44 PM
