1983 Oldsmobile Delta 88 Window Skips
OLDSMOBILE
DADDEE808
1983 Oldsmobile, Delta 88, 307eng, 4dr.
The rear driver side window only rolls up halfway then the gear starts to skip on the belt. It goes up to the point at which it begins to skip. The switch works, the motor works and the window does not go off track! How can I replace the belt by itself w/o having to buy a whole motor assembly?!?
Nov 8, 2007 at 6:46 PM
BMRFIXIT
  • 19,053 POSTS
[quote:23a86664a8="daddee808"]1983 Oldsmobile, Delta 88, 307eng, 4dr.
The rear driver side window only rolls up halfway then the gear starts to skip on the belt. It goes up to the point at which it begins to skip. The switch works, the motor works and the window does not go off track! How can I replace the belt by itself w/o having to buy a whole motor assembly?!?[/quote:23a86664a8]
It’s called window regulator
It’s been a while since I did one but if I recall u can buy it along
To close the window 4 know open door have a helper push the switch when it reaches the point help the glass up using 2 hands
Good luck
Nov 8, 2007 at 9:47 PM
Suggested Repair
Replace the window regulator, which can be purchased separately rather than as a complete motor assembly. To close the window temporarily, have a helper hold the switch while you guide the glass upward with both hands once it reaches the skipping point.
Conversation Summary
The owner of a 1983 Oldsmobile Delta 88 reports that the rear driver-side window rises only halfway before the gear skips on the belt. The switch and motor work, and the glass is not off track; the owner wants to replace only the belt. The expert identifies the part as the window regulator, says it can be bought separately, and suggests assisting the glass upward by hand while a helper operates the switch.
