Window Wont Roll 95 Cutlass Ciera HELP
1995 OLDSMOBILE
EKRAVANYA
My drivers side auto window stopped working. wont go up. makes no noise. all other windos ok from same contol panel. could this be a fuse??? I have no money and no othe form of transport. can I fix this my self? what do I need to do- the owners manual is no help. This is a 1995 with a 6 cylinder engine. I hope it doesn't rain before some one sees this please answer soooon.......
Aug 28, 2007 at 3:41 PM
TROYANDERSON13
  • 9 POSTS
[quote:213df4c18e="ekravanya"]My drivers side auto window stopped working. wont go up. makes no noise. all other windos ok from same contol panel. could this be a fuse??? I have no money and no othe form of transport. can I fix this my self? what do I need to do- the owners manual is no help. This is a 1995 with a 6 cylinder engine. I hope it doesn't rain before some one sees this please answer soooon.......[/quote:213df4c18e]
the motor in the door is probably shot just for the drivers door. take the door panel off to get to it
Sep 22, 2007 at 5:50 PM
HOTDRAGONZPLACE
I had the same problem with my 95 olds ciera and it turned out that it was just the window motor. I went down to the local salvage yard and bought one for about 25 bucks and replaced the stubborned thing and it turned out fine, however I have come across quite a few people that said after replacing the front driver side motor the back driver side motor goes out soon after and it was true for mine! Hopes this helps a little.
Oct 23, 2007 at 4:06 PM
