vehicle shakes when brakes applied/ 1993 olds bravada
1993 OLDSMOBILE
MRRICK69
i just replaced both front brake calibers,pads,idle arms and pitman arms but when i apply the brakes the front of the the suv begins to bounce or shake very hard , not side to side more like the front tires seem to bounce . i know my frame is a little bent but i was told by a frame shop that this would not create these actions what do you suggest?
May 1, 2007 at 5:06 PM
[quote:77933dadd1="mrrick69"]i just replaced both front brake calibers,pads,idle arms and pitman arms but when i apply the brakes the front of the the suv begins to bounce or shake very hard , not side to side more like the front tires seem to bounce . i know my frame is a little bent but i was told by a frame shop that this would not create these actions what do you suggest?[/quote:77933dadd1]
Did you mic the rotors before you replace the pads.
May 1, 2007 at 6:34 PM
