1997 Oldsmobile Cutlass ATF Leak
OLDSMOBILE
B.BRITT
1997 Oldsmobile Cutlass supreme 130,000 miles.
My son is losing transmission fluid and it had a slight leak in the pan which we sealed and it still is losing fluid. The other day I checked his radiator expansion tank and there is an oily substance in it. Could the transmission fluid leak into the radiator? Is the radiator cooler internal in this car? And can it be fixed or do you have to replace the radiator? How difficult is it to replace ourselves? engine is a 3.1L with A/C
Aug 23, 2007 at 4:56 AM
SERVICE WRITER
  • 9,123 POSTS
If you have transmission lines going into the radiator, and that is the leak, you should replace the radiator. I have seen gus plug the radiator and join the cooler lines or put in a external cooler.
Aug 23, 2007 at 9:01 AM
Suggested Repair
If the transmission cooler lines enter the radiator and that cooler is leaking into the coolant, replace the radiator. An alternative seen in service is to plug the radiator cooler ports and join the cooler lines or install an external transmission cooler.
Conversation Summary
A 1997 Oldsmobile Cutlass Supreme with a 3.1L engine is losing transmission fluid after a pan leak was sealed, and an oily substance was found in the radiator expansion tank. The owner asked whether fluid can enter the radiator through an internal cooler and whether the radiator must be replaced. The expert said that if the transmission lines go into the radiator and that is the leak, the radiator should be replaced, or the cooler ports can be plugged and the lines joined or routed to an external cooler.
