Power windows
OLDSMOBILE
EDSTA
Hello folks... My 3.5L 2002 Olds Intrigue has 85000km on it. The driver power window quit on me, I replaced the driver door switch bank, and it worked fine for about 1 month. It has started to act up again, it has quit several times, and it always appears to fail only on start up after it has been sitting for several hours. Not sure if it's just in my head or not, but it seems to only give troubles when the car is sitting in the hot sun??? I know that probably sounds werid
Thanks for any help you guys can give me, I'd appreciate it!
Sep 13, 2007 at 1:50 PM
BMRFIXIT
  • 19,053 POSTS
[quote:5483837e81="edsta"]Hello folks... My 3.5L 2002 Olds Intrigue has 85000km on it. The driver power window quit on me, I replaced the driver door switch bank, and it worked fine for about 1 month. It has started to act up again, it has quit several times, and it always appears to fail only on start up after it has been sitting for several hours. Not sure if it's just in my head or not, but it seems to only give troubles when the car is sitting in the hot sun??? I know that probably sounds werid
Thanks for any help you guys can give me, I'd appreciate it![/quote:5483837e81]
hello there
I have seen that so many times
I will suggest to turn key on or start engine
E brake on
open the door at the door jam look for the harness try to work the window switch as you
shake and twist the harness
and see what happen
most likely you have a broken wire in that harness
good luck
Sep 13, 2007 at 3:41 PM
