1999 Oldsmobile Cutlass P0442 EVAP Leak
1944 OLDSMOBILE
SEANNIKE
I have 1999 cutlass oldsmobile a 3.1 engine, My question my check engine light is on and is showing a code of p0442 how do you find and fix the problem???
Jun 13, 2007 at 6:21 AM
SERVICE WRITER
  • 9,123 POSTS
That is a small leak in the evaporative system that controls the fuel vapors. I would start by "smoking" the system. Since this is not a machine a d-i-yer would have, look at the fuel cap and the sealing surface of the cap. If there is a question of a poor seal, replace the cap, clean the neck surface the cap seals to and lightly coat it with vaseline. IF that doesn't resolve it, your best to take it into a shop that is capable of troubleshooting this. If you do, make sure the tank is between 1/4 to 3/4 full or the test for the evap will not run.
Jun 13, 2007 at 7:23 AM
Suggested Repair
Inspect the fuel cap and its sealing surface. If the seal looks poor, replace the cap, clean the filler neck, and lightly coat the sealing surface with petroleum jelly. If the code remains, have a shop smoke-test the EVAP system with the tank between one-quarter and three-quarters full.
Conversation Summary
The owner of a 1999 Oldsmobile Cutlass with a 3.1 engine has a check engine light and code P0442. The expert identifies a small evaporative-emissions leak and recommends checking or replacing the fuel cap and sealing surface, then professional smoke testing if needed, with the tank between one-quarter and three-quarters full.
