oldsmobile silhouette air conditioning
OLDSMOBILE
GEORGE TUCKER
  • 5 POSTS
I have a 94 oldsmobile silhouette and the air conditioning unit is making a whining noise all the time. It still blows relatively cold air and I can still hear the compressor kick on and off. I don't know if there is anything inside the compressor ie...bearings that would go bad over time or not. Everyone keeps pointing me towards the clutch but I'd like to know for sure if there is a way I can tell.
My question is how can I tell if it's the clutch making the noise or if it's the compressor itself?
If it is the clutch, how do I remove it? Is there some sort of clutch removel/puller I can purchase?
Jul 7, 2007 at 6:24 AM
SDHEN
  • 15 POSTS
Whining? Are you sure its the AC? If you are quite sure I would take it to a mechanic. Most places will diagnose your problem for free. Dont let it go bad because the whole system may need to be replaced if that pump dies and water enters.
Jul 7, 2007 at 1:15 PM
GEORGE TUCKER
  • 5 POSTS
Yeah, I'm positive that it's the ac. At first I thought it was the transmission making the noise and I took it in. The tranny mech took a look, and decided it wasnt the tranny. We took off the serpentine belt and the noise went away. The next thing we did was put the st-scope on it and it is coming from the ac unit.
Jul 7, 2007 at 5:29 PM
ROCKWOOD84
  • 103 POSTS
there is a bearing in the a/c compressor right behind the pully and you have to have the clutch removal and install tool. it all comes in the same box i think the price is $30.00. what size motor?
Jul 22, 2007 at 8:00 AM
GEORGE TUCKER
  • 5 POSTS
It's got the 3.8
Jul 24, 2007 at 3:26 PM
ROCKWOOD84
  • 103 POSTS
quote="George Tucker"]It's got the 3.8[/quote]
you can take the serpentine belt off and see if you can move the pully back and forth on the sides. if it will wobble a bearing is probably going out.the clutch has a bearing and the compressor has a bearing. the clutch bearing will make a noise with a/c off.as it turn when the belt turns.the compressor bearing will only turn when a/c is on.if it is the clutch bearing you can pull the clutch[have to get a removal tool and install tool] if you have an autozone close to you they might loan you these.you will have to leave a deposit then get it back when you return tools. you will be able to do the clutch bearing without taking a/c compressor off. you will also need pully puller to pull pully off.the bearing is under the pully and has to be
pressed out and new one pressed back in. if it only makes the noise when a/c is on it will probably be the compressor bearing then the compressor will have to be taken off. and you will need a new seal pack for the compressor as the seal has to come out to knock the bearing out.gm has a seal kit for $45.00
in front of the seal there is a big snap ring that has to come out and you will have to split the a/c compressor the push the seal out.maybe it is just the clutch bearing. let me know how it goes...
Jul 25, 2007 at 3:08 AM
GEORGE TUCKER
  • 5 POSTS
It sounds like it must be the clutch bearing then since it makes the noise all the time. Thanks again for the assistance.
Jul 29, 2007 at 10:27 AM
ROCKWOOD84
  • 103 POSTS
tuck, when you go to get the bearing ask for a pully bearing last time i put one in 10 years ago the price for one was $35.00. it has to be pressed out and the new one pressed in.but the good thing is you can do this with a/c compressor on the van.take the belt off. loosen the nut and pull the clutch off then pull the pully off.get the new bearing in. then bump the pully on the press the clutch back on with the clutch tool . don't lose the keyway while you are doing all this.
Jul 29, 2007 at 6:41 PM
GEORGE TUCKER
  • 5 POSTS
Great. It's a relief knowing that I don't have to pull the compr. off the thing. I was NOT looking forward to that. But...even though I don't think it's the best looking car on the road (not even close) it does me a good job of hauling my road bikes around for different rides. It may have been a gracery gitter back in the day but now it's more of genreal purpose, haul all my sports equipment around.
Thanks again for all of the help. As soon as I get back home from this middle eastern desert, I'm gonna get 'er all fixed up.
Jul 30, 2007 at 11:28 AM
