oil filter blowing out
OLDSMOBILE
KEMELEATHERS
I am working on my 1997 Oldsmobile Cutlass; it is an automatic; 3.1 Liter; with 155000 miles. I recently had a lifter that was sticking and therefore replaced the lifters and had the heads resurfaced. While the engine was apart I noticed excessive sludge build up in the lifter valley and head area. I cleaned the lifter valley and flushed the pan the best i could without removing it prior to putting the engine back together. In attempting to start the vehicle now the oil filter gasket blows off the car. I have tried 3 different types of filters and same result with each. My question is could sludge have plugged the oil pressure regulator ? Any help with this issue quickly would be wonderful. Thank You...
Oct 22, 2007 at 11:38 AM
You need to remove the oil pan and investigate thoroughly. check the oil pressure relief valve.
As pressure builds in the oil system, it exerts pressure. A spring-loaded "pressure relief valve" built into the oil pump (or near the pump) opens when pressure exceeds a certain limit (typically 50 to 60 psi) and either reroutes oil back into the pump's inlet or the oil pan. This prevents a dangerous buildup of pressure that could rupture the oil filter or blow out press-fit oil plugs.
Oct 22, 2007 at 11:47 AM
